02-09-2025
06:48 PM
02-09-2025
09:02 PM
computergeek541
Hi,
I just ported my number to telus. I want to make sure my contracted is cancelled. It will no longer let me login and chnage my plan. Is it canaceled or what do I need to do?
02-09-2025 06:56 PM
@hairbag1 wrote:successfully porting out will deactivate your account. You can use this link to ask Customer Support to scrub all info from your old account.
Truth be told @hairbag1 , you can request this but I highly doubt they do it. What proof do we have it's done? Plus technically it's on the Telus network which the customer moved to.... not sure there is any reason to bother a CS Agent for this. Just my opinion.
02-09-2025 06:52 PM
hi @alllllllllll there is no contract here and account is closed after port. You can try to lock in my account and you shouldn't be able to do , so that confirms your account is fully closed
02-09-2025 06:50 PM
