Puerto Rico phone plan
AFERNS
Hi i got a US talk and text plan. I’m in Puerto Rico and I can’t find a network. It says SOS … can someone tell me how to get a nework? Thank you!!
Chalupa_Batman
Hello @AFERNS
Not knowing what phone you have makes it a bit trickier to help. So please share that with us.
You can go into your network settings, cellular and turn off automatic. If you see Tmobile, click on it and then also make sure your data roaming is turned on. Then reboot the phone. You should be fine. However, if that doesn't work, you may wish to check the VoLTE list to make sure your phone will work outside Canada.
https://www.publicmobile.ca/en/mb/get-help/articles/volte
hi @AFERNS
PM US roaming add-on and plan includes  Puerto Rico and the US Virgin Island
try changing your network to 4G or LTE or even 2G and see what Network carriers it shows.  I think you need AT&T , T-Mobile or Verizon.  If you see none of those, it is a network issue there.  Since PM relies on those US varrieea, PM really cannot do much if there is no coverage in your particular area
TMitchell
It appears there should be coverage... but no older network 3G coverage.    4G and 5G only.
US Roaming Troubleshooting | Public Mobile
Usually a restart of phone corrects issue but the link above will walk you through a few other checks.
