01-04-2024 03:56 PM
i need a new request sent to Bell about porting my number. the msg timed out on me. I have contacted bell and they said a new request must be sent from public mobile
Service
01-04-2024 05:04 PM
I had a similar situation when I tried porting over from Chatr but was able to get it resolved when I called the porting team! I suggest contacting the number of the porting team. They should be able to help you 🙂
01-04-2024 04:06 PM
ok thanks
01-04-2024 03:58 PM
Check your inbox I will send you the number to call to do ot again
01-04-2024 03:57 PM
@spike123 Will send you porting team number right away and get it fixed
01-04-2024 03:57 PM
Hi @spike123
You can call Public Mobile porting team to provide the correct Info and get status update. I will send you the porting team number. Please check your Community inbox for my message
![](/skins/images/813D49D689E0D681E39391EAB60FD666/responsive_peak/images/icon_anonymous_message.png)
