Dropped Calls
El-Tabador
Hello Team just wondering if you have issues now or in the past few months with dropped calls ?
Saravann
we had that last month or two--- occasionally we had dropped calls..
@El-Tabador  Not here no . Maybe try reseting network settings also you can try the phone on 3G see if that helps for voice also check
Outage map in your area:
https://istheservicedowncanada.com/
HI @El-Tabador
what phone do you have?
try Reset All networks forst
Try your sim in another phone and test it for couple days
if same,  please submit a ticket with CS Agent here:
