10-31-2022 05:02 PM
I just updated my plan, BUT.. i had a couple of friend referals and they did not pass on the savings to my new plan.
any reason why?
Plans
10-31-2022 05:14 PM - edited 10-31-2022 05:14 PM
Did you pick change now? If you did then you don't get your rewards until your next renewal. You would have needed to schedule a change plan on next renewal to get your rewards for your previous 30 day cycle.
10-31-2022 05:04 PM - edited 10-31-2022 05:06 PM
@70Irish Rewards don't get applied if you changed your plan now instead of scheduling for next renewal. They'll be available for next renewal though.
edit: unless you're on the new points system, in which case you need to accumulate 15 points and then redeem them to use against your payment.
