phones
LoloF
At the past i bought a phone from PM . I look now for new phone . Could you tell me where the page for that in PM //....... thanks
HI @LoloF  not with Public Mobile at the moment
What kind of phones you are looking for? check around, there are good used phone.  Just do not buy off others online, at least be really careful
hycm53
Mobil Klinik is owned by Telus, you can check your local Mobil Klinik store:
https://shop.mobileklinik.ca/collections
hairbag1
@LoloF
the CPO phones previously offered are no longer available. Nobody in this Community is sure if they'll return.
@LoloF
at the moment, look like PM removed it.  If you like the PM CPO selection and price, check with your local Mobile Klinik stores.  MK is also owned by Telus and the prices are pretty much the same, with even bigger selection of CPO phones
@LoloF  PM removed option for buying phones for now unfortunately hopefully this will change soon
