Phone activation
Wyatt1231
I have paid , downloaded your esim, tried everything possible , and still no active phone connection ????
1 REPLY 1
hi @Wyatt1231
make sure you remove your old carrier sim card, disable old eSIM
set PM sim to active and set as Primary
then Reboot your phone and reset network settings
if same, ask PM agent to help , you can submit ticket by direct message:
