Friday
While trying to subscribe, I somehow selected esim, but my phone is not esim compatible. Public Mobile tells me to contact them but I can never get through. There is no option I can see to step back in the process to change this, Is there any other way to step back the activation process to change the selection to a physical SIM.
Friday
Thanks, I finally figured out how to submit a ticket.
Friday
hi @john_1
so, you tried message them? That is for message them , it won't "says no agents available at this time."
please use the link to message support agent
and then check your Community inbox for agent's reply
Friday
Hi, apprecitate your response, I am new to this, I have tried to contact help but never get a response. Seem t be stuck in a loop that always says no agents available at this time.
Friday
If you need physical SIM you have to open a ticket and explain situation.
Friday
HI @john_1
Please ask PM support to help. They will ask you to either get a sim from Telus or Koodo store or ship you a physical sim
Please message them using this link:
Friday
no need to step back on the activation process, instead, ask PM to help to double check if your phone really not esim compatible or ask them to change back to physical sim
Open ticket with PM using the orange charbot icon on the lower right. Start the question Submit Ticket, then choose Contact Us to get to the ticket open screen
