01-17-2025
09:38 PM
01-17-2025
11:11 PM
computergeek541
Hi do I need to renew my subscription on PM to get esim
01-18-2025 01:11 PM
the phone's esim would work, but the problem with this phone is that it does no have enough LTE band to have a stable data connection. This won't be a great phone to use on PM network
01-18-2025 01:01 PM
Hi slusagm
I have Moto G54 5g it says it's esim compatible
01-18-2025 12:59 PM
Hi hairbag1
On PM app it doesn't give me an option to purchase an esim.
01-18-2025 12:55 PM
most esim compatible phone would work here
what phone do you have?
01-18-2025 12:54 PM
Hi hTideGnow
No I'm not suspended I have subscription but I just wanted to purchase an esim to see if my fone is compatible.
01-17-2025 10:21 PM
hi @Icey786000
is your service suspended now? You need to resume service first, then buy the new esim. Login My Account and pay to resume first. If you have trouble with 2FA, click Didn't receive code and select Send email to get the code via email
01-17-2025 10:02 PM
renew subscription and esim are two different things
if you just want esim, make sure your phone is esim compatible (if unsure, tell us what phone you have). Then download the Public Mobile app no your phone, login and go to Account page to buy sim card and choose esim and follow the steps
01-17-2025 09:51 PM
do you mean you wish to upgrade to esim ? If so, use the PM app to log in to your PM account to purchase the esim.
Do you mean to just renew your subscription ? If so...when you activated your new PM account you used a valid credit / debit card and it was set to autopay by default.
If you could clarify your question please.
