01-09-2022 09:33 PM
hello i need help with i just put in the sim i was away from the country i cant receive messages i don't know why tnx
01-09-2022 09:48 PM - edited 01-09-2022 10:54 PM
You have chosen a solution....do you still need help? Or has @Anonymous provided that to you?
Edit: that
01-09-2022 09:40 PM
You should know that you're dealing with other customers, just like you.
We are not employees or staff of Public Mobile.
Presuming you haven't been inactive for over 90 days, you simply need to add sufficient funds to restore your services, then reactivate.
Sometimes adding an extra dollar or so will get things rolling - don't worry, the 'excess' payments will roll over to next renewal 30 days from now.
01-09-2022 09:39 PM
Like I said in my previous message, you can call 611 to get your account status, or just sign in to selfserve.publicmobile.ca
01-09-2022 09:37 PM
close all Browser and do clear cache and cookies for any Browser,
and try open one Browser incognito mode,
go sign in to Self-Serve, to review your account,
and if still not fix it follow this,
and if can't fix it you need To Contact Customer Support Agent by CS_Agent, and Explain your issue to them can solve your issue, they are nice service Team the will help you 100%.
Here’s How To Contact Customer Support Agent by Submit a Ticket,
Good Luck.
01-09-2022 09:36 PM
Would be nice to know more details. Is your plan active? Are you able to log in to self serve or call 611 to find out if you need to top up your account or replace your autopay credit card?
01-09-2022 09:36 PM
can u check if its activated ? i toped up my balance
01-09-2022 09:34 PM
Reactivate A Suspended Plan
Missed a payment? After your plan expires, all you need to do is top-up your balance to keep the current plan going. You have up to 90 days to make a payment and, after doing so, your payment cycle will restart and your service will resume.After 90 days of non-payment, your account will be permanently deactivated, which means you will:
