12-30-2024
01:14 PM
12-30-2024
10:13 PM
computergeek541
12-30-2024 01:57 PM - edited 12-30-2024 01:58 PM
The CS Agent helped fix the error! All is good now!
12-30-2024 01:41 PM
Thanks for your reply - I checked the statement and it was processed on the 27th so I don’t think it was pending when I activated my SIM today. I’ve reached out to a CS Agent to see what else I can do.
12-30-2024 01:18 PM
Check with your CC statement to see if the first charge is Pending. You should be charged once you activated your new SIM then the Pending charge will be removed and changed to a Posted charge.
You can also confirm this by contacting a CS_Agent directly by pm them.
12-30-2024 01:16 PM - edited 12-30-2024 01:18 PM
@tonyhadjisI think this is just a caching issue so do not pay again. If you are accessing your account from the website, try signing in to your Public Mobile app on your phone, or you can try the website again but clear your browser's cache, or you can sign in incognito mode or trying a different browser
If you are still having issues reach out to a support agent. You will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
