12-31-2024
03:52 PM
12-31-2024
04:18 PM
computergeek541
12-31-2024 04:53 PM
Yes I sent a private message to one of their agents but I haven't received a response yet.
12-31-2024 04:43 PM
@MarkRidd at Public Mobile all support is through messages. Agents are live but online messages back and forth.
Did you use the link I sent you? I don't know if they are still open being New Year's eve. Normal hours are 9:00 am to 10:00 pm est.
They reply via your inbox.
12-31-2024 04:18 PM
So when I re-downloaded the app and tried to log into my account it takes me back to the same screen as the screenshot above. It just says "Subscription not activated" and recommends customer support.
Are there any live customer support agents? I keep getting "bot" support and it's not been very effective so far in resolving my issue.
Thanks.
12-31-2024 04:13 PM
Ok I'll try that and follow up afterwords
12-31-2024 03:59 PM
@MarkRidd is that the App?
Can you uninstall and try again? If same, contact support at the link below.
