No 5G on iPhone 12, only LTE?
Jooy
Hi all, I am a new subscriber (a few hours ago). iPhone 12 Pro running iOS 18.2. Coverage map shows 5G for my area (Brighton, ON), but phone only connects to LTE. I set voice and data to "5G On" but that hasn’t had any effect. I cycled airplane mode a few times, and restarted phone, but no luck. Speed test giving 8.5 Mbps down, 2.5 Mbps up.
Any ideas out there? Thanks.
8 REPLIES 8
Jooy
Thanks @BKNS27, I tried that. Looks like I get 5G, but just not on my property. I don’t understand how PM is creating their coverage map I guess.
Jooy
Thanks@Phil_Adelphus . Good to know. I drove closer into town and then 5G worked there. Funny though, no where on my property do I get 5G, although the coverage map solidly suggests it is covered.
Phil_Adelphus
@Jooy  I have an iPhone 13 set to 5G Auto and in my house it is always on LTE. If I set it to 5G On it still only gets LTE.  I do get 5G and 5G+ elsewhere, including 5G out in certain places in my property.  One thing with 5G is that it doesn't penetrate buildings as well as LTE.  I do get good speeds on LTE though, above the limit for PM's 4G plans quite often.  Have you tried when you're out and about locally?   I'm assuming the obvious, that you did sign up for a 5G plan!
@Jooy
I am assuming you have Roaming enabled.
Also, is your iPhone set on 5G Auto in Voice & Data and Allow More Data on 5G in Data Mode?
Jooy
Thank you @hTideGnow,
I used your instructions to submit a ticket, and I will see how that plays out.
hi @Jooy
did you try your phone outside your town? and check with friends who are using Telus or Bell and see if they have 5G (PM shares the same network as Telus and Bell)
you can also ask support agent to confirm , submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can submit  ticket by direct message:
Jooy
Hi hTideGnow, and thanks for your reply.
OK, I tried Reset Network Settings just now. I checked for Carrier Profile, but a new one wasn’t offered (Carrier is Public Mobile 61.0). I have iOS 18.2. But still only LTE is showing up.
I did read that account changes to speed can take 48 hours, but I am not sure if this also applies to new accounts (5G from the beginning).
HI @Jooy
Brighton has 5G coverage
https://www.publicmobile.ca/en/on/coverage
make sure you have iOS 14.5 and above to get 5G on iPhone 12
also update the Carrier Profile and try Reset Network Settings
