11-09-2023 03:50 PM
Hi
My subscruption was renewed on October 25th and I changed my plan on the next day..
So I was charged on October 25th and 26th with two different plans..
I am wondering if you guys give me overchrged amount on my credit.
I read the warning you coudln't give a refund and that's why I am asking you to give me credit instead.
Thank you in advance.
11-09-2023 04:29 PM
I'm pretty sure I would not make mistake to push change now button when changing a plan.
Thank you for letting me know what made this happen.. and for your time as well.
11-09-2023 04:26 PM
Thank you for your help. I was looking for submit a ticket link..
I appreciate for your tip as well. (ask nicely..)
11-09-2023 03:52 PM
HI @encho that is normal if you use Change Now option during plan change. You should have used Change On Renewal and have the plan change later
Agent might or might not help, it really case by case, but still submit a ticket with them and ask nicely, tell them you don't know the change buttons difference. Please use this link to submit ticket:
11-09-2023 03:52 PM - edited 11-09-2023 03:52 PM
you should have selected Change on Renewal. You can use this link to message a CSA for their help...
oops...heres that link....https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
