11-09-2024 12:17 PM
Both my wife and I are on Public Mobile and are getting quite a few texts not going through even though the recipients are recieving.
Support is saying that it is a coverage issue, but, this only started
11-09-2024 12:46 PM
hi @demitch you probably already using Google Message on Samsung phones. But try uninstall and reinstall it. (on both phones ). Make sure you backup important messages first before doing so
11-09-2024 12:45 PM
@demitch Does it happen where ever you are or just in one location ? Are you able to test the SIM cards in another phone and see if it helps any ? I’m thinking your right about being the PM network if it was only affecting one device and not both
11-09-2024 12:42 PM
Android S21 FE , both our phones are android.
I have reset both the network and cleared cache.
Believe its a network issue as both of our phones are affected , but its intermittent.
11-09-2024 12:21 PM
11-09-2024 12:20 PM
@demitch Maybe try phone set to 3G/4G/LTE or even 5G and test all networks . Can also try resetting network settings and see if they helps . Also if you have another phone to test might be helpful determine if its device issues or account /network issue
