Anyone know how long I can roam in U.S. without issue?
11-08-2024
06:13 PM
11-08-2024
06:18 PM
computergeek541
I plan to go south for an extended period of time (a couple of months). Does anyone know if it is an issue that most of the usage is roaming? Thanks!
Service
11-10-2024 06:56 PM
hi @Joe_is_cool the Canada US plan includes data and inbound/outbound calls when you are in US too. You can call US and Canada when you are in US. So, basically you use the plan in US like you are in Canada. You can subscribe to the plan without worries
11-10-2024 06:52 PM
The customer support of Public Mobile is pretty responsible, but they are nowhere near knowing about their product. We had in total 10+ messages and the CS agent either replied with irrelevant information without reading my questions, or losing context quickly and making me start over and repeating my questions. At the end, I am giving up after "The plan includes incoming and outgoing calls to the US while you are in Canada. If you travel to the US, you need to add a US roaming add-on."
11-09-2024 12:39 AM
It’s the U.S.-CAN plan
11-08-2024 08:49 PM
If you have the Canada plan. You will need to purchase Add-on for calling, texting and data.
What is the plan you are on?
11-08-2024 06:26 PM
If you get USA/Can plan it is unlimited calls and texting in/out.
As per 'issues' it will depend in connection to 'partners' PM has in USA. I hope you will have good connection all the time and if not try manually switching to PM partner. Plus VoLTE enabled might might help.
11-08-2024 06:20 PM
@Joe_is_cool There is no time limit mentioned in PM website , unlike other carrier that specify x amount of time
11-08-2024 06:17 PM
@Joe_is_cool technically there is no specific time frame with the Canada-US plans.
Works just like home with a VoLTE enabled phone on PM whitelist.
