03-27-2025 07:47 PM
I cannot open a ticket for my SIM issue. My number got transferred to Public mobile but not to my SIM. Now I don’t have any service. I need help. I could not open a ticket.
03-27-2025 08:16 PM
You can also call for porting assistance. Check out you messages. Good luck.
03-27-2025 08:06 PM
Did you reply to the text from your previous carrier you are porting over to PM with the old SIM in your phone?
If you did, your old SIM will continue to work for about 2 hours until porting is completed.
03-27-2025 07:56 PM
If you have no service on the sim, you need PM to check the system again to confirm sim and account both setup correctly
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
03-27-2025 07:51 PM - edited 03-27-2025 07:52 PM
First, try rebooting your phone. If that doesn't work, place your old sim card into the phone to confirm you no longer have service at your old provider. If you do still have service, create a ticket and a CS Agent will help you transfer it.
Send a private message to a CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 .
IMPORTANT MESSAGE:
We are NOT Customer Service Agents. We do NOT work for Public Mobile. We are Customers just like you who try to help others while earning credits towards their cell phone bill. Please do not share any personal information with anyone here or in a private message.
