11-09-2024 03:27 PM - last edited on 11-10-2024 03:52 AM by computergeek541
my mobile data is not working. I am using Samsung s24fe. I already have tried switching off my device, turning on-off aeroplane mode, resetting mobile data and refilling APN settings.
I have full mobile data on my account. There is no data limit set on my phone. I don't know why it is not working for me.
Please help me to fix this issue.
11-09-2024 11:10 PM - edited 11-09-2024 11:17 PM
hi @Kamal8 make sure no other sim is showing up on the sim manager screen. Disable all those others eSIM profiles
And check VPN screen and delete the VPN profile there
Setting -> Connection --> More connection settings -> VPN
if that still does not work, try your PM sim card in another phone
11-09-2024 09:49 PM - edited 11-09-2024 09:50 PM
@Kamal8 Maybe try reset network settings , or if possible try your sim if physical sim card in another phone? If same
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send direct private message to support .
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
11-09-2024 09:26 PM
My Data is full and i have same APN settings as you mentioned above. Still not working .
I turned off auto payment for a month because i was travelling. I turned it back on just few days before entering in Canada. Unfortunately data and calls are not working.
11-09-2024 03:35 PM - edited 11-09-2024 03:48 PM
@Kamal8 Have you used up your monthly data bucket allowence ? Do you have data turned on in phone settings ?
also check APN settings
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN type: Leave blank
