one more gig
08-27-2023 01:57 PM
Good morning p.m.
I have the $25, 3G, one gig plan. It's a perfect fit.
I have a new job and fill out 2 online forms each morning and one gig is not quite doing it. I want to get one more gig of data.
Wow. $15 for one more gig. That's expensive. What can I do thats cheap?
Add-Ons
08-27-2023 10:38 PM - edited 08-27-2023 10:39 PM
The recent change pm made to data add ons now expiring 30 days after purchase (unless you purchase a new one before the current one depletes or expires that extends all of the add on data another 30 days**)is a terrible policy change but fits into telus's plan to increase their ARPU by migrating customers to plans $40+ which offer lots of data for cheap but is still very expensive if you don't need much more than 1gb.
**If your data needs are very small purchasing the $5/200mb data add on might be an option but timing of purchase/expiry and the renewal of your plan is important since plan data gets used first.....purchasing once every 30 days to extend all add on data expiry could work in your situation. ($25+$5=$30/1.2gb)
If you are just running close to the edge then employing all of your data saving tools and turning off background data ( this can use up to 38% of your data) could be enough to keep you within your 1gb data allotment.
08-27-2023 02:53 PM - edited 08-27-2023 10:40 PM
@KenR1 Public Mobile isn't really playing in the space you're looking at (at the moment). For $14 extra dollars you're getting significantly more data (20GB) at faster speeds (4G vs 3G), but I get that's a 56% increase in spend.
Alternatively you could consider Lucky Mobile who has a 5GB plan for $30 with auto pay.
08-27-2023 02:16 PM
thanks for pointing that out....didn't read that until you did.
08-27-2023 02:16 PM
Awesome good point of you thank you
08-27-2023 02:14 PM
@hairbag1 Sure does signed my daughter up on that flash sale today . But it’s only for new activations not existing customers
08-27-2023 02:12 PM
08-27-2023 02:08 PM
do you have access to free wifi in your new job...maybe you could use that, if it's available.
08-27-2023 02:02 PM
I'll let the super know tomorrow maybe they can accommodate?
08-27-2023 02:02 PM
if you do opt to purchase a data add-on, be aware they have a 30 day lifespan. I'd suggest you upgrade to a plan with a bit more data...as suggested above.
08-27-2023 02:01 PM - edited 08-27-2023 02:01 PM
unfortunately, public mobile does not have an offering between $25 and nearly $40.
It really sucks and they should offer something in the $30-$35 range with like 5-10 GB or something.
Thing is, and this has been discussed by others recently, they’re trying to eat into the $40+ market with their plans and offerings it seems.
08-27-2023 01:58 PM - edited 08-27-2023 02:01 PM
