08-27-2023
09:30 PM
08-28-2023
12:59 AM
computergeek541
I recently discovered the 2 dollar autopay discount isn't applicable any more. So how do I disable it?
My Account
Payment
08-27-2023 10:25 PM
Yup then it seems as if it is enabled by default. Thanks!
08-27-2023 09:48 PM
how long you have joined PM?
if you joined PM after Jan 25th, 2022, your rewards will be on Public Points by default, that is the program with 5% points back instead of $2 Autopay discount.
08-27-2023 09:38 PM
Can you tell me how to join the rewards program or is it by default?
08-27-2023 09:36 PM
Thank you so much for your help 😊
08-27-2023 09:32 PM
did you change to the new Rewards Program Public Points? if so, you won't be getting the $2 Autopay discount anymore but just getting the 5% back in points
You want to disable Autopay? If you do, make sure you manually load fund ahead of renewal
you can do so on Payment page, then click Manage Subscription, there you can toggle Subscribed Off to disable Autopay
