08-27-2023 02:45 PM - last edited on 08-27-2023 02:49 PM by computergeek541
I can't stop a blocked caller from using my voicemail so I want to change my phone number to my old Telus Landline number that still comes up not in use. Is that something I can do?
08-27-2023 10:22 PM
Ask customer support to see if they can find it and assign it to your account. If it's been more than 90 days since you had active service on your landline you can look for the number in the available number's pool to change to in your account's profile page.
08-27-2023 03:52 PM
hi @Goppy PM agent sometime will help to assign old number owned by people before. But I doubt they will assign number that you owned when you were using Telus landline service. You can try submit a ticket and ask them but i highly doubt
08-27-2023 03:47 PM
How to port number from “Blank” to Public Mobile
First, make sure your number can be ported by checking on this link
https://secure.koodomobile.com/checktransfereligibilityparrot/default.do
Or log in to your Public Mobile account
Then on your right side you’ll see this box. Click on Transfer Phone Number.
Then enter the number you want transfer and continue to next step
Good Luck.
08-27-2023 02:46 PM
@Goppy If it’s available and it’s a Telus number it’s possible . You need to ask support to help you
private message To CS_Agents click
VVVVV Link below VVVVV
