09-20-2024 01:17 PM
I am trying to get into my account - I forgot what email address I used and it is sending the verification to the email which I can't access, I need to get in asap to pay my bill, I am getting no where with the chat box, I can't open a ticket
09-20-2024 01:42 PM
Thank you, I will do that. I still need access to my account so I sent message to customer support
09-20-2024 01:28 PM
hi @Camille71
if you need to pay now, get a voucher from Shoppers Drug Mart and then you can load the voucher by calling 1-855-4PUBLIC
but if you want to login My Account, you will have to message support with the link above
09-20-2024 01:20 PM - edited 09-20-2024 01:22 PM
@Camille71, the link below will ask for your mobile number and will send an email to your account. If your phone has email notifications turned on you should see a new message arrive
https://eversafe.id.telus.com/user/forgotemail
The other option is to contact a CS agent but they will be asking verification questions.
To open a ticket through the Chatbot: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
09-20-2024 01:20 PM
@Camille71 You can also purchase a voucher from shoppers drug mart and load the funds *611 but here’s a direct link for support
09-20-2024 01:20 PM - edited 09-20-2024 01:21 PM
If you cannot log in to your account you have to open a Ticket so agent can help you out.
In chatbox type 'ticket' and follow prompts, answer questions until you are presented with a link to open a Ticket.
You can modify where 2FA goes and select to receive it by SMS to your phone.
