no mobile network - was working just stopped today
Golfer08
My phone has been working all along and sometime today i lost the network and I cant call or receive calls or text. It says no mobile network. Any thoughts as to what happened, or how to fix.
JL9
Glad to hear you resolved it if an issue like that happens again and that solution doesn't work you can always get another device and put the sim in there to see if it is a device issue or a sim/network/plan issue.
Simon learned that from us !!
Glad to hear you got it working again.
Yup, that was #2 in my suggestion above as well, @Golfer08
Sometimes SIMon the chatbot is a very useful tool - glad it all worked out!!!
Golfer08
I actually fixed my own problem. I went to Simon the bot which said toggle airplane mode on/then off, and restart the phone. It worked
HALIMACS
@Golfer08
Perhaps there's a TELUS outage in your area?
TELUS Service Status
When this happens, other options to get going are:
  1. reboot device
  2. toggle airplane mode on/off
  3. reset network connections
  4. remove and reinsert SIM card
Also, check your account status in self-serve to ensure it reads, Active.
[ #2 today ....,,,,Luddite {
Meow
Did you check your PM account? Does it say Active?
Did you try to re-seat SIM? Reboot phone?
Can you try your SIM in another phone?
