04-10-2023 07:10 PM
Cannot seem to receive or call out. Text message works but not calls. It either rings busy or call failed. Tried resetting the phone. place sim in other unlocked phone same results
04-11-2023 10:26 AM
04-11-2023 09:21 AM
it could be just the long wekend and they respond slower than usual, please message them again for update
if you open ticket via Chatbot, you should have a copy of the ticket in your Community sent box. Please use that to reply CS agent for update
or you can message them again here:
04-11-2023 09:16 AM
I'm having the exact same issue. I've tried all the recommendations that SIMon suggested, put a ticket in a few days ago with customer services, but still haven't heard anything nor has their been a change. Super frustrating.
04-10-2023 07:24 PM
Hi @JS2026 start with changing the network.
if that does not work, pleas submit ticket with PM agent
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
04-10-2023 07:20 PM
no outbound or inbound calls, only text messages
04-10-2023 07:15 PM
Hi @JS2026 then it will be Network problem. outbound calls ok?? try to change the network to 3G only or WCDMA only and it could work.
04-10-2023 07:13 PM
not new port. have had my account for years with never an issue until now
04-10-2023 07:12 PM
hi @JS2026 is the "text" just IMessage?
did you just activated and ported in your number? maybe you didn't reply YES to approve the porting and porting not completed?? Call the porting support team and confirm. Please check the Community inbox, I will send you the number there
