Additional Data plan
Swmrgrl-KPF
I paid extra $15 to add 1 extra gig as I ran out two weeks early. The funds were taken from my bank account 8 hours ago and still no change to my data.
@Swmrgrl-KPF  do you see the addon on My Account?  Login using Incognito mode and check
Also, reboot your phone once and check if it works
Make sure you don't have any data limit enabled on your phone.  if you do, disable it first and test
@Swmrgrl-KPF
Refresh your browser by clicking on the circular arrow.
Yummy
To get most up to data account status:
Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
DO you see 1GB add-on on your account at all?
