01-18-2023
05:25 PM
01-18-2023
05:37 PM
computergeek541
01-19-2023 12:40 AM
Why are you chsnging it?
01-18-2023 11:37 PM - edited 01-18-2023 11:38 PM
01-18-2023 07:49 PM
Shelli321 those are good suggestions for activating a new account and I remember reading those instructions but I also got some help from the personal who referred me. Mariogi needs to change the simcard to a new one which needs to be done in the account by going to the profile link.
01-18-2023 06:47 PM
Just follow the instructions that were included with your SIM card. Do all of this on your computer. Then the process is fairly simple to port over your current cell phone number to Public mobile. Remember to answer "YES" when prompted by your old cell phone provider that you want to port over.
When I ported over, I took too long to respond to the text and it was cancelled.
01-18-2023 05:49 PM - edited 01-18-2023 05:50 PM
Use COMPUTER not phone to do this
01-18-2023 05:41 PM
login 5o My Account on a desktop and laptop only (don't do it on Mobile, there is glitch with mobile site)
Click Change sim card from Quick Link on top right and follow the steps
01-18-2023 05:37 PM
@Mariogi it’s best to do this on a pc also
01-18-2023 05:27 PM - edited 01-18-2023 05:27 PM
If you’re changing your SIM card on an already active public mobile account, log into the self-serve site and go under the change SIM function.
If you’re a brand, new customer, tap the activation button at the top of the page.
