05-12-2022 12:25 PM
05-14-2022 11:06 AM
05-13-2022 06:16 PM
@hairbag1 wrote:Let us know when you sort this one out.
Good luck getting feedback from customers...
05-12-2022 12:56 PM
If you recently purchased your phone, click on this link to see if the phone hasn't been reported stolen or blacklisted....
https://www.devicecheck.ca/check-status-device-canada/
05-12-2022 12:45 PM - edited 05-12-2022 12:45 PM
Can you SMS?
Did you try to turn phone off, remove SIM, wait 2-3 minutes, pit SIM back and power up phone?
Did you try to reset network?
Is your account active?
05-12-2022 12:40 PM
HI @paulojbonna There is no outage according to Telus site:
https://www.telus.com/en/qc/outages
But did you try to reboot your phone ?
If you have another phone around, put your PM SIM into the other phone and check if it works there
Even if you don't have a 2nd phone, try to reseat the SIM once
Also, if you look at Mobile, Available Network, do you see Public Mobile there?
05-12-2022 12:35 PM
There might be a Telus outage in your area.
Check map in your area:
05-12-2022 12:34 PM
Some more details would be helpful.
Is your account status active or suspended?
A few basic troubleshooting advice:
Reboot phone
Network reset of phone
Remove SIM card and re-insert and reboot phone
Maybe try your SIM card in another working phone. That would help determine whether hardware issue versus PM service problem.
Also can check whether your phone became blacklisted.
