messages
06-28-2023
09:05 AM
07-02-2023
11:25 AM
Dunkman
06-28-2023 09:09 AM
@Woody2 - were you ever able to see voice messages show up?
Try restarting your phone.
If that doesn't help, try a reset of the networks:
Go to Settings > System > Advanced > Reset options. Touch Reset Wi-Fi, mobile & Bluetooth > RESET SETTINGS. Touch RESET SETTINGS. Try to reconnect to Wi-Fi, cellular data, and Bluetooth, or try to share your internet connection again.
See how to set up: https://www.publicmobile.ca/en/ns/get-help/articles/voicemail-faqs
06-28-2023 09:08 AM
@Woody2 so, you meant you didn't see a badge showing Voice mail waiting? but if you call Voicemail, you can retrieve VM?
The badge notification has been an issue with iPhone, it seems like a device issue
For you, you can try to Reset All Networks first and see if it helps
If not, you might want to ask support to reset your VM on the system and see . To engage support, please open ticket by messaging here:
