Travelling Out Of Province - Will My Phone Work?
HNR1
Hi,
I live in Ontario and I'm planning to travel next month to BC. Will my phone work there? If yes, do I have to purchase an add-on?
HNR1
Thanks. And thanks for bringing some laughter to the community
HNR1
Thanks
dust2dust
So you'll need a passport to enter the foreign  regions beyond the outskirts of Toronto. And outside of Toronto uses a different currency so you'll need to exchange what you have. 🙂
Of course the service will work. Even with an older provincial plan. It will still let you call the province you're in. Data and text are nation-wide as is your likely Canada-wide plan. Canada goes from the Pacific Ocean to the Atlantic Ocean and to the Arctic Ocean.
@HNR1  Yes it will work assuming you have Canada wide mins . All plans do now . So unless it was a province wide plan from a long time. Ago . I say you’re fine nothing to do . Just enjoy  your trip
@HNR1   Yes, it should, as long as you have Canada wide plan, both data and voice would work when you are out of province
