7 hours ago
I’m travelling soon to Italy.
- Does PM sell any international package for data and calls when I’m in Italy?
- If they don’t offer a package in Italy, what settings should I change on my phone when I buy a SIM card from there in order to avoid getting charged for roaming there?
Thanks
3 hours ago
You can use WhatsApp when connected to wifi. Other than that, you can purchase a SIM that works in Italy from Amazon.
4 hours ago
Thank you abtest. Do you have any idea where to buy a SIM there, or is it better to buy an e-SIM. and where to buy from? It’s my first time.
Thanks
4 hours ago
There is no roaming in italy available. You do not need to disable/change anything on your phone. There will be no roaming charges since this is a prepaid service.
