3 hours ago
2 hours ago
@hairbag1 yes, this is also a great option as long as the device supports eSIM since they do not offer physical SIM cards.
2 hours ago
airlo.com has competitive pricing on travel data packages for use in most country's including Greece. Then you can use Whatapp and imessage wherever you are with or w/o wifi.
3 hours ago
@77Crosswind wrote:Thanks for the quick reply.... I wonder if standard iphone texts will work with Wifi abroad ?
iMessage will work with your local wifi as well as WhatsApp will also work.
3 hours ago
@77Crosswind I think it will but I'll know for sure in a few weeks when I'm also in Europe 🙂
But if not, I'm planning to use WhatsApp over WiFi
3 hours ago
3 hours ago
Thanks for the quick reply !
3 hours ago
Sorry, but there is no Public Mobile service available in Greece.
3 hours ago
@77Crosswind unfortunately not. Public Mobile has no roaming outside of the US without a package.
You would have to use wifi or local SIM in Greece or Europe.
3 hours ago
no add-on or plan for use anywhere other than Canada or USA...sorry. You'd need a local sim or a voip app.
3 hours ago
@77Crosswind unfortunately PM only offers roaming in the US. For all other destinations you will need to get a local SIM/phone plan or if you have access to WiFi you can use apps like TextNow, WhatsApp etc
