lost phone
08-21-2023
11:18 AM
08-24-2023
10:17 AM
Dunkman
Hi
Lost my phone in halifax basin.
Have a new phone and SIM however when I try to log into my account the self serve system wants to send a verification code to my old phone, which I obviouly cant get. How can I get into my account so that I can change the SIM card to reflect my exisitng number.
Thanks
My Account
Service
08-21-2023 11:37 AM
@Ryjacq11 Try tapping resend code a few times you should get option to send code to email instead or reset password option can work also then once logged into your my account you SIM card swap the sim like this or get support to help you
SIM SWAPPING profile tabs
Note only do this on lap top or computer/ not mobile device
link to support
private message To CS_Agents click
VVVVV Link below VVVVV
08-21-2023 11:26 AM
When you try to login to your account, click on Resend Code and have the 2FA code sent by email.
08-21-2023 11:20 AM
HI @Ryjacq11
you were correct to login My Account to change sim
To get the security code, at that screen, click "Didn't receive code?" and then select Send email
if the option is not there, then just submit a ticket with CS agent here and they can help with sim card change :
