08-21-2023 10:10 AM
Is it worth it to switch over to public points or should I keep my rewards??
Rewards
08-21-2023 11:45 AM
@Haycloud18 Remember Cash is the king! So keep old rewards as I did.
08-21-2023 10:31 AM
STAY with the old Rewards system, you get instant monthly credit off your bill and you get more credits.
New Points system, you need to collect 15 points for a $15 credit off your bill from the points you collect from 5% of your monthly bill.
08-21-2023 10:21 AM
@Haycloud18 Keep old rewards . They’re more lucrative and if you switch to points it’s one way street and can never go back to old rewards . Just don’t ever switch is the general consensus around here . And you can change plans with out having to switch to points
08-21-2023 10:12 AM
A quick answer to your question, don't look, don't think and just stay on the old system 🙂
quick advise for anyone who consider changing: If you are gone, you are gone. That is a point of NO RETURN!!
in summary
- $2 Autopay is no longer there and replaced with 5% , you get less UNLESS you have the $40 plan or above
(but you get 5% for your other Add-on purchases as well) - No more loyalty rewards, meaning the loyalty discount of $1/month up to $5/month will disappear. Instead, they will only give $10 each year on the anniversary.
For someone with PM between 1st to 12th month
The old reward system will give $0 that year, versus $10 at the end of the 12th month with thew new system
For someone with PM between the 13th and 24th month:
The old reward program will give $12 that year ($1/cycle), versus $10 at the end of the 24th month with the new system
For someone with PM between months 25th and 36th:
the old reward program will give $24 that year ($2/cycle), versus $10 at the end of the 36th month with the new system
for someone with PM between months 61 and 72 (and every year after that after that point)
the old reward program will give $60/year ($5/cycle) versus $10/year under the new system - You can no longer apply $1 or $2 you got to the bill right a way, you have to collect enough to 15 points to cash out $15 in one shot
Also, you have to remember to convert your points to dollars once it reaches 15 points. PM no longer automatic apply the reward discount.
On the other hand, the goodies for new system,
- 5% Points back for add-on purchases as well
- add-ons are around 33% cheaper when you redeem with Public Points
- you can use 1 point for lucky draw, so, technically you bet $1 and can win an iPhone
