07-09-2026 06:32 AM
07-09-2026 09:10 AM
If one enables extended absence would that also put on hold the iPhone build in IOS voice mail?
07-09-2026 07:10 AM - last edited 3 weeks ago
voicemail cannot be disabled but you can setup Extended Absence, which basically do the same:
To setup and enable Extended absence, dial into your voicemail and log in with your PIN.
In the main menu, press 3 (manage greetings),
then 4 (manage extended absence greeting),
then 2 (record a new extended absence greeting) and record a message that indicates to your caller you are not accepting messages.
Then press 4 to turn on extended absence
Finally, press 5 to disallow anyone to leave you a message. Problem solved!
To return to receiving inbound messages, should you wish to at a later date:
then 4 to turn off your extended absence greeting
After doing this, your previous personal greeting goes back into effect automatically, and callers can leave you messages again.
07-09-2026 07:09 AM
@Plss wrote:How do I remove the voicemail off my phone
Hello @Plss
There is no way to remove or cancel voicemail. You can however turn on extended absense greeting to stop callers from leaving a message.
Call your voicemail and log in using your password. Manage Greetings by pressing 3. Then Extended absence press 4. Then press 2 to record a message stating your not accepting calls or just don't say anything and follow the prompts to save it. Then press 4 to activate it. Press 5 to prevent callers to leaving a message.
