08-15-2021 02:39 PM - edited 01-06-2022 03:08 AM
Hello, I recently activated two sim cards under one email address. I haven't gotten the welcome welcome for registration so I did it on my own for one of the numbers but I would like to link the second number to my online account. How can I do that?
08-15-2021 03:58 PM
If you send a private message use this as a guide for efficiency.......
Send a private message... Contact the CSA's (formerly moderators) by sending a private message and leave a detailed message explaining your issue and the info to verify your account by including the following information:
If you cannot remember your pin # include at least three ( if they apply)of the following:
The average wait time is 2 to 4 hours but be prepared to wait up to 48 hours for non urgent requests. Current wait times are about one hour and are probably even less as I have had some very quick responses in tne past week.
Keep an eye on your private message box the envelope icon next to your avatar for a little number to pop indicating a message from the CSA's(formerly moderators.) Responding promptly will speed up service times.
Do not post any of this info in the community only in your private messages when communicating or contacting the Moderator_Team.
To send a private message to the moderators click below : https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
08-15-2021 03:01 PM
@Momma22 wrote:Thank you! I will see what I can do. I appreciate your quick response. I tried the bot thing at the bottom right hand side of the corner but I didn't get anywhere with it. I will try again.
Try this.
08-15-2021 02:58 PM
08-15-2021 02:45 PM
One email address for each PM account. You can't have two number with one account/email address.
You will need to contact customer service agent to help separate your accounts.
Click on the chat bubble icon on the right lower corner of website to start ticketing process to contact CSA. Type: I can't login. Follow the prompts to submit ticket.
CSA will ask a few questions to verify account ownership and then should be able to help you. Response times can take a few hours. Check your private message inbox (envelope in upper right corner of website).
