iphone 11 and 5g plan
Sarah37
1gb of data wasn't doing it for me, so I upgraded to the 50gb plan. I understand that iphone 11 doesn't support 5g, and I'm fine with that.
Ever since I upgraded by data, though, my access to the internet has been incredibly slow and sporadic. (I'm comparing this to my previous 3g plan with PM.)
Besides buying a new phone, which I am not interested in doing, how can I solve this?
@Sarah37 wrote:
The reset network settings seems to have done the trick. Thanks for helping me.
As @hTideGnow has provided you with a great answer...please award him/her/it the Solution instead of me. I'm sure that would make him/her/it happy.
@Sarah37 wrote:
Thanks for this. I'm not entirely sure where "network mode settings" is. Is this the same as going to "cellular data options"? There I can choose LTE or 3G.
I am currently do the reset network settings.
That's the correct place to set LTE.
Sarah37
Sarah37
hairbag1
@Sarah37
set it to LTE and leave it alone.
hi @Sarah37
did you check the network mode settings?  is that set to Auto or 4G?
and try Reset network settings
