Purchase Plan and install anytime?
Clapodie
I would like to purchase the Canada/USA plan now and install after I get back from my trip outside of Canada so I don't loose out on the promotion....does that work? Can I order now and install at any time?  Or you think promotion will still be available 3-4 weeks from now?
2 REPLIES 2
hairbag1
@Clapodie
your only option is to select Change on Renewal. Nobody knows when or if PM will remove those Cdn/US plans. My suggestion would be to get it while it's available. Just select Change on Next Renewal to get your best value.
added pic
cbPM51
Looks like a regular choice for the time being. But to guarantee it, sign up nkw with "on renwal", rather than the "now" choice.
PM appears to be making lots of plan changes. The trend is "pay more/month.
I would lock in by ordering$34 plan now.
Likely aoril might see $40 as the minimum for 50gb usa-canada.
