4 weeks ago
4 weeks ago
I already have a ticket open with someone from customer service from yesterday. When i found new info
4 weeks ago
@Kerrie8828 - I am thinking you should contact support:
⬇️ Click the link for an Agent * ⬇️
If the link above doesn’t work, please go here to create a ticket to CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
* - CS_Agent will typically get back to you within 48 hours. They work 7 days a week from 9 AM to 10 PM EST. You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for an agent because they may notify you asking for some information via Private Message, in your mailbox by clicking this link here: Messages
4 weeks ago
i have an iphone 14 pro. i exited out like you said. on my computer, i was able to scan and download it using a QR code. now it is installed but it won't activate. uggggghhh
4 weeks ago
@Kerrie8828 - What phone do you have? iPhone or Android?
If it says "Connecting to Network" it says that it is trying to connect to a cell tower automatically. You could dismiss it.
Make sure to have a Wi-Fi or another SIM Connection to download the eSIM profile.
If it is iPhone - then if you want to - you can actually just dismiss the popup and it will automatically download / activate it in the background.
You may want to contact CS_Agent if it has been 4 hours of loading / installing 🙃
