07-10-2023
12:28 PM
07-10-2023
06:54 PM
computergeek541
Hi,
My name is xxxxxxxxxxxxxx and I used publicmobile service. unfortunately I moved to Korean and couldn’t use your service no longer. But I have a problem of unsubscribing because I can’t get the code number which is needed for login when I try to reach on my account.
I need to hold up or cancel the service. Because I even don’t have a bank account in Canada any more so there will be a critical problem for payment.
Is there any other way to get the code for login or If you possible, Could you make my account unsubscribe?
my Email address is xxxxxxxx@xxxxxxxxxxxxxxxx
You can contact me by email.
I’m looking forward to your answer ASAP.
thanks.
07-10-2023 01:04 PM
thanks!!! I could solve the problem!! you’re a genius!
07-10-2023 12:54 PM
PM just changed to a new EverSafe login system and you need to complete the setup on this new system. Have you login to My Account since EverSafe was introduced?
If you have already created an EverSafe id, you can ask the code to send to email instead
On the screen it is expecting you to enter the code, click Resend code and then choose Send email
If you have not created an EverSafe id yet, you won't be able complete the part to link your My Account with the EverSafe ID, that needs a working phone with a working PM sim using SMS. (Sending the code to email would not be a choice until EverSafe id is fully setup)
Try these workarounds, it could bypass the SMS in linking My Account with EverSafe ID
If none of those workarounds helps, please open ticket with support by direct message here:
Once you got back into My Account, you can then go to Payment page, Mange Subscription and disable "Subscribed" to turn off Autopay
https://myaccount.publicmobile.ca/en/account/my-payment/manage-subscription
07-10-2023 12:43 PM - edited 07-10-2023 12:43 PM
@sunshin @Please message support to remove the credit card on file to cancel
message support directly
while your already here and logged in the community you can send a private message To CS_Agents click
VVVVV Link below VVVVV
