New Customer
07-10-2023 10:00 AM
How can I join public mobile from a different carrier with the same number. I cannot find a number to call public mobile support.
Joining Public
07-10-2023 12:23 PM
they are not even responding
07-10-2023 12:21 PM - edited 07-10-2023 12:21 PM
@Jay007 wrote:I do no understand what you mean. only thing I want here is either you fix the issue or refund me. simple
HI @Jay007
we are just customers like you in the Community
You really need to reply messages with CS agent to get your issues resolved
But PM is prepaid and no refund
If you need immediate help, with a call centre you can talk to , maybe PM does not have everything you are looking for. Check with Koodo or Telus as they have a full call centre support model
07-10-2023 12:19 PM
07-10-2023 12:16 PM
HI @Jay007
PM does not have a call centre. Even those with one, it is not abnormal that some people waited an hour just to talk to an agent
Which provider you try to port from? You might want to reconsider if you need one with quick immediate reply, PM certainly not one You might want to check with Koodo or Telus instead
07-10-2023 12:13 PM
we use cell phones for important things and I've been waiting for 2 hours
07-10-2023 12:12 PM
if there is no refund, this is a very bad way to treat a customer
07-10-2023 12:10 PM
HI @Jay007
sorry, there is no refund here
Just give them a bit of time. It is good that you got an initial reply, that means they are on your case
07-10-2023 12:09 PM
@Jay007 They should reply very soon . Just need to keep eye on your community mail box . Your almost there we all be here to help walk you through it
07-10-2023 12:08 PM
all this have been done already please lets be realistic. I don't have all day. if this is not possible I can go back to the previous carrier and get a refund from pm
07-10-2023 12:05 PM
@Jay007 They don’t respond as quickly as we do but they will reply again they just need you to first answer some verifications questions to get started
07-10-2023 12:05 PM
no worry, it is now they stop reply, they will come back.
07-10-2023 12:03 PM
cs agent has stopped replying. this process is becoming very stressfull
07-10-2023 11:34 AM
07-10-2023 11:34 AM
@Jay007 Yes , this is the effort your taking now to keep old number on new PM SIM .
07-10-2023 11:34 AM
HI @Jay007
they don't reply instantly 🙂
probably within 2 hours. Keep checking your community inbox for their reply
07-10-2023 11:32 AM
I have done this and no reply
07-10-2023 11:23 AM
HI@Jay007
you need to submit ticket with CS agent.
07-10-2023 11:22 AM
@Jay007 wrote:when I scan the QR code it says I should contact pm
@Jay007 that's good, you replied the porting text and just a problem with eSIM
what phone model is yours?
and please open ticket with PM support first:
07-10-2023 11:22 AM
@Jay007 So message support as advised and have them re provision the sim for you and you will be all good to go
private message To CS_Agents click
VVVVV Link below VVVVV
07-10-2023 11:22 AM
07-10-2023 11:21 AM
I replied to yes. now all I see is S0S
07-10-2023 11:21 AM
HI @Jay007
which old provider you were from?
your eSIM is not activating? what phone you have? iPhone? what model?
07-10-2023 11:19 AM
07-10-2023 11:18 AM
I am not from voodoo prepaid
07-10-2023 11:16 AM
@Jay007 Well then just message support as PM requests
07-10-2023 11:15 AM
I don't have an sim with my old provider
07-10-2023 11:12 AM - edited 07-10-2023 11:15 AM
07-10-2023 11:11 AM
it says I should contact pm for Esim activation
07-10-2023 11:03 AM
You can message support here directly:
Did you get to the eSIM installation step? Either the app will ask for your permission to do it for you automatically, or you will get a QR code to install yourself.
If you missed the step, there is a QR code in your Welcome email. Open it from a computer, or another device, then use your phone to scan it to install the eSIM profile on your phone
Once you installed the eSIM profile, (or If you got passed that step), try to reboot your phone once.
If it still does not connect and if you have any active sim on the phone , disable them (eSIM/Physica sim) or remove the physical sim. Then click Reset All Networks on your phone and it will work. (Please note that Reset all Networks will also erase your saved Wifi and Bluetoosh connections, but you just need to add them back after)
07-10-2023 11:01 AM
@Jay007 Are you using a iPhone XS or later anything before that is not eSIM compatible .but for support here the link
message support directly
while your already here and logged in the community you can send a private message To CS_Agents click
