05-03-2022 09:19 PM - last edited on 05-04-2022 01:03 AM by computergeek541
Hi
I want to know how to get my information to log-in.
After several attempts, I got a message from your service team to release the lock
I failed log-in and forget password. Please let me know how to activate it.
ID might be (e-mail addresses removed).
05-03-2022 09:23 PM
@Seungyoung - wait over 15 minutes, then try again. You likely temporarily locked up your account by too many failed attempts. If you still cannot reset your password, submit a ticket with CSA.
To contact the Public Mobile Customer Support Agent (CSA)_Team, there are two methods to reach them:
1 - Faster use this link to: Get Help With SIMon the Public Mobile chatbot
OR
2 – Slower - Use this link to:
Contact Public Mobile Representatives (CSA) by submitting a message(ticket) to them here:
Private Message to Public Mobile Customer Support Agents (CSA)
** Please edit your post to remove your personal info. This is a public forum.
05-03-2022 09:22 PM
@Seungyoung if you have some possible email in mind, try to use the Forgot Password link https://selfserve.publicmobile.ca/forgot-password/
Enter all the possible email you might have used. if you got the correct one, you will then get to Step 2 and you will need to answer the security questoin.
if you are unable to self-reset it that way, open ticket with PM Support and they will help:
1. For faster response (2-48 hours), Click on the bubble in the lower right to request CS Agent assistance, or use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
