05-03-2022 07:57 PM
Phone lost, we did not register to access the account online. How can I suspend an account without using Self Serve?
05-03-2022 09:17 PM - edited 05-03-2022 09:17 PM
05-03-2022 09:11 PM
problem solved via PM customer service. thanks a lot!!
05-03-2022 08:18 PM - edited 05-05-2022 05:48 PM
Do you have a local retailer to purchase a new unactivated SIM card? You may be able to purchase one and have the CSA perform a SIM swap for you. This would eliminate the need to suspend via lost/stolen and allow you to create your self serve account.
To contact customer support :
Submit a support ticket via Simple--Simon the chat bot Click here
Or if you prefer or cannot submit a support ticket you may send a private message : Click here
To pre-verify add in your private messaging only your full name, address, email, phone # & 4 digit account pin #
05-03-2022 08:05 PM
Thanks I just did. So waiting for reply now.
05-03-2022 08:01 PM
Yes, as @softech says do it right away so they can put it in lost/stolen status for you asap
05-03-2022 08:00 PM - edited 05-03-2022 08:01 PM
@rtahina Don't wait, open a ticket with PM support via direct message , they will first validate your identity and will help
Also, hope you have set it up earlier and one of these find my phone service can help
