forbidden A1
Rana7
Has anyone resolved the Forbidden A1 problem? I have cleared the cache/ cookies and it is still a problem. I can't access my account even though my credit card was charged. I would like to chat with a live agent, but I can't login to create a ticket, it just says 'forbidden A1'. Help needed!
Phil_Adelphus
@Rana7   If you're still having the problem and can't log in send a private message to customer support agents using this link, you only need to be logged in to this community for it to work as it by-passes the chatbot
eddieO
@Rana7, If you are trying from the web browser try accessing through the PM app or vice versa depending on where you are starting from
Meow
No issues here. Everything works as expected.
