04-09-2023 11:48 AM
Why am i getting data warnings when i have a 20g plan and i have only used 2.4 gigs. And why do they shut my data down when i reach 5 gigs
04-09-2023 03:25 PM - edited 04-09-2023 03:25 PM
It sounds like a limit you have set on your phone itself, which has nothing to do with Public Mobile. Change or remove the data cap and/or warning in your device settings.
To be sure you should login to your Public Mobile account in Incognito Mode to verify that you have data remaining in this cycle.
04-09-2023 01:13 PM
Check your phone settings. Go into the data section and check out that
04-09-2023 12:23 PM
You may be confusing GB with MB. - don't believe that PM will shut down your account because it still has 5 GB of data left. There must be another reason.
04-09-2023 11:59 AM
if you do as I've suggested, you'll be able to do 2 things...find out how much data you're plan has and how much you've used up.
I'd also suggest you disable data to apps you don't use on a regular basis.
04-09-2023 11:58 AM - edited 04-09-2023 12:00 PM
I don't believe PM shut your data off... it's most likely that you have a data cap on your device. you need to disable "set data limit" Google it. you may also disable "set data warning" and you will not receive those warnings from your device
04-09-2023 11:56 AM
Some phones have a setting where there is a data limit. Your phone likely has this set up. What model phone do you have? Likely a phone set up issue versus PM service problem.
04-09-2023 11:55 AM
hI @Robocom maybe what you see is cached usage.
you can use the spinner option as advised by @hairbag1
or you can also login My Account again using Incognito/Private/Secrete mode. That would save the manual clicking of the spinner as there are couple to refresh but getting updated info on the whole My Account
04-09-2023 11:55 AM
To be very sure how much data you have, check again after:
Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
Sometimes SMS regarding usage is sent in error...
04-09-2023 11:55 AM
It on my phone i receive the data warning. not on the pc. They actually shut my data down at 5 g and i had to use wifi last month
04-09-2023 11:51 AM
