8m ago
I have a can/USA/México plan and I'm in Arizona and the data isn't working. I have gone through multiple steps I have found and still nothing. I also sent an email to support with no response. I have a Google 7a wondering if there are any ideas on this.
36 seconds ago
Yep I forgot to say that. I have my. Data roaming on. As I was driving to Arizona my data would go from working to an exclamation mark. Now that I'm here it will not work at all.
3m ago
make sure you have enabled Roaming in settings to be able to use the data in USA.
