28m ago
38 seconds ago
Hello @nanabrockway
I'm sure you're 100% aware of this since you signed up for Public Mobile. Public Mobile is a self serve service. You are in charge of your account at all times. Simply log into your account using the email and password you used to sign up, then on Overview, you'll see usage there. It's that easy. And if you can't remember your log in information, click on Forgot Email and or Forgot Password. And if that doesn't help, reach out to PM.
https://expert-messaging.publicmobile.ca/guest/chat/
Once you get back into your account, please find some time to play around with your account. Click on some tabs, see where things are. You'll be amazing and surprised at what you can do on your own without any help.
23m ago
you can log in to your account using the app, and tap Usage Breakdown. It'll show you how much data in your plan and how much is left this period.
