@cs_agent
DarenL
@CS_Agent i am getting 7B1 your phone is not activated on the network.  I just put sim card from my flip phone to an old iphone 6.  It can recieve calls, and send receive messages.  Please activate.
14 REPLIES 14
maximum_gato
@DarenL
I'm assuming everything worked out for you?
DarenL
Thank you!  Contacted.  I assume CSA will deal with this on Monday.  This support community system is...different.  Thanks for being knowlegeable.
maximum_gato
Lol...if the phone is recieving calls and texts that it cannot be blacklisted or locked to another carrier.....? 😆🐈
@DarenL
It sounds like your activation or provisioning of your Sim card did not complete correctly. If reprovisioning of your Sim card by the CSA does not work to fix the issue you may need to get the CSA to add outbound calling to your account by "ticking" the feature option within your account's features set up. Contact customer via the link supplied by @Chalupa_Batman .
Chalupa_Batman
Hi @DarenL
Your best solution right now is to contact a CS Agent. They need to reset the network on their end. If you haven't reached out to them before about this, please click on this link to create a ticket. Advise them you are getting the 7B1 code and they will reset your network then you'll have to reboot once they are done.
Let us know if this resolves your problem. Good luck
hi @DarenL the phone never worked on PM or Telus network? could be an incompatible phone.  What make and model is that?
DarenL
It is not carrier locked per the imei searches
DarenL
Yup it’s clean Your device HAS NOT been reported lost or stolen and is not currently on the national blacklist
@DarenL  is the iPhone 6 locked to another provider did you but it from market place by any chance also check
Check that it’s not black listed
Check the Status of Your Device in Canada | https:/
hi @DarenL
if it is a new phone, check here to see if it is clean
https://www.devicecheck.ca/check-status-device-canada/
DarenL
So, simcard in old phone works.  I have an account, just want to use simcard in another phone.
I have tried reinserting sim card, rebooting and resettinf network settings in new phone.  I get bars on the public mobile network and I can do messages and receive calls in, I just cannot call out.  I get a 7B1 error.  How to “activate phone on network”. @CS_Agent
"from my flip phone to an old iphone 6"
hi @DarenL
so, the problem is the flip phone? is it a new one?  put it back and see if it works now
Chalupa_Batman
Hi @DarenL
Did you sign up for a plan? Do you have an account? We need more information please.
@DarenL  Try rebooting the phone or reset network settings , if you out the SIM card back in the other phone does it work ?
