cellular network not available for voice calls
arkadysht
Why do I receive this message "cellular network not available for voice calls"
7 REPLIES 7
Community_QA
never see that error myself. but data working?
is there no 3G in your area ?
darlicious
@arkadysht
Do you have an iPhone?
To pre-verify your account include your full name, address, email, phone # and 4 digit acct pin #
@arkadysht  -  try manually select the 3G / WCDMA ONLY network in your Mobile Connections area in your settings (temporarily) for dropping or unable to make incoming/outgoing calls.
3G or WCDMA 2 (1900 MHz ) and 5 (850 MHz) bands  makes the phone compatible, which is needed for phone calls.
Confirm your phone is compatible:
https://www.kimovil.com/en/frequency-checker/CA
https://willmyphonework.net
EDIT: perform a reset of your network settings, and see if things improve.
Yummy
Out of range?
Can you send/receive SMS? Internet working? Similar ever happened at THAT particular location you are at now?
@arkadysht
Check your phone signal to see if it is at 3 bars and also see if Public Mobile is shown on cellular network selection.
Connect to PM if signal is strong.
0PX9O4
@arkadysht
This message can occur because of coverage issues, or if your phone has problem connecting to (reading) the SIM card.
You may try removing and gently re-inserting the SIM card into your phone, and then restarting it.
 @arkadysht : Can you set your phone to automatically scan for networks. Then scan for networks and find and choose Public Mobile. Then flip in/out of airplane mode and see what happens.
