12-18-2024 07:47 PM
Is the network (Public Mobile) having issues in and around Nelson, BC today - December 18, 2024?
12-19-2024 12:17 AM
Thanks for your time and suggestions! As weird as it went to SOS Only, it came back onto the network!!! Weird!!!
12-18-2024 09:26 PM
hi @Dato
do you know anyone in your area using Telus or Koodo or Bell or Virgin or Lucky? do they have similar problem today?
12-18-2024 08:21 PM
Assuming you have a physical SIM, is there Anyone in your household you can swap SIMS with to see if it’s a device issue or SIM issue? I had a SIM with a hairline crack that would cut the service in and out at times. Perhaps it’s the same issue. Good luck
12-18-2024 08:21 PM
I'm in C'gar and all seems to be up and running here today. Power was out this morning...but cell service was unaffected.
12-18-2024 08:13 PM
I did that already. Nothing is expired. Payment went through.
12-18-2024 08:05 PM
@Dato wrote:I rebooted the phone 3 times already. I also set it on Airplane and then off as it is suggested on the internet ... but nothing ... instead of Public Mobile as a network it shows SOS Only
OK. Try this. Dial 611 or log into the phone app and see if your payment went through. Maybe your credit card expired or didn't go through.
12-18-2024 07:58 PM
12-18-2024 07:53 PM
12-18-2024 07:50 PM - edited 12-18-2024 07:52 PM
check here
https://www.telus.com/en/qc/outages
but I don't think there is any reported outrage, probably just minor local network problems
