02-20-2025 09:07 PM - edited 02-21-2025 09:39 AM
Update: This mobility outage is now solved.
https://www.telus.com/en/bc/outages
There is a current outage within Montreal, QC for mobile devices. The services impacted are:
Fallback Coverage
Please note, there is 911 wireless fallback coverage provided by an alternate carrier in this region. If you wish to enable a potential wireless fallback connection beyond 911 access through an alternate carrier in this region, please ensure your mobile device network is set to automatic, and allow time for the wireless fallback connection to establish before retrying.
You will see "EXT" if you are connected to a partner carrier.
02-20-2025 11:12 PM
@fixin1 wrote:Please note, there is 911 wireless fallback coverage provided by an alternate carrier in this region. If you wish to enable a potential wireless fallback connection beyond 911 access through an alternate carrier in this region, please ensure your mobile device network is set to automatic, and allow time for the wireless fallback connection to establish before retrying.
There have been past cases of a cell phone service outages at carriers and the fallback for emergency calls didn't work. In such cases, there times when a cusotmer would need to remove/disable the SIM card to make such emergenecy services phone calls.
02-20-2025 10:23 PM
thanks @fixin1
in fact with the 911 fall back, you don't need to do anything. When you dial 911, the phone would look for partner's netowrk
also, please remember the partner network won't work for regular calls
